[Qgis-user] Problems with image clipper
    Agustin Lobo
    alobolistas at gmail.com
    Thu Oct  1 00:20:27 PDT 2009
Thanks Bob,
after a fast testing, it seems that works fine on ubunty jaunty with
qgis 1.3.0
It's a great implementation of a critically missing tool!
Agus
Bob Bruce wrote:
> I have fixed this problem with the Image Clipper. I have fetched it
> and tested it with version 1.3 on Windows and it worked fine.
> Hopefully it will work on other OSs as well.
>     Bob
> On 9/30/2009 8:54 AM, Bruce, Bob (CON) wrote:
>> Agus and Nikos:
>> 			Thanks for testing. I've found the problem and
>> will release a fix later today. I'll let you know.
>> 	Bob
>> -----Original Message-----
>> From: qgis-user-bounces at lists.osgeo.org
>> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Nikos Alexandris
>> Sent: Wednesday, September 30, 2009 8:28 AM
>> To: Agustin Lobo
>> Cc: qgis-user
>> Subject: Re: [Qgis-user] Problems with image clipper
>> On Wed, 2009-09-30 at 15:03 +0200, Agustin Lobo wrote:
>>> Hi!
>>> After installing image clipper (Qgis 1.3.0, ubuntu 8.10)
>>> 1. The plugin is still listed as not installed.
>>> 2. At restarting QGIS, the following error is displayed:
>>> Traceback (most recent call last):
>>>   File "", line 2, in
>>>   File "/home/alobo/.qgis//python/plugins/image_clipper/__init__.py",
>>> line 22, in
>>>     from imageclipper import ImageClipper
>>>   File
>>> "/home/alobo/.qgis//python/plugins/image_clipper/imageclipper.py",
>> line
>>> 9, in
>>>     from dlgimageclipper import ImageClipperDlg
>>>   File
>>> "/home/alobo/.qgis//python/plugins/image_clipper/dlgimageclipper.py",
>> line 1
>>> IndentationError: unexpected indent
>>> Python version:
>>> 2.5.2 (r252:60911, Oct  5 2008, 19:42:18)
>>> [GCC 4.3.2]
>> Image Clipper fails to work (also) for me under Jaunty 64-bit, QGIS
>> 1.4.0-trunk (revision 11691). The following is reported at start (same
>> as Agus' traceback):
>>   File "", line 2, in
>>   File "/home/nik/.qgis//python/plugins/image_clipper/__init__.py", line
>> 22, in
>>   File "/home/nik/.qgis//python/plugins/image_clipper/imageclipper.py",
>> line 9, in
>>   File
>> "/home/nik/.qgis//python/plugins/image_clipper/dlgimageclipper.py", line
>> 1
>> Python version:
>> 2.6.2 (release26-maint, Apr 19 2009, 02:15:38)
>> [GCC 4.3.3]
>> Nikos
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> No virus found in this incoming message.
>> Checked by AVG - www.avg.com
>> Version: 8.5.409 / Virus Database: 270.13.115/2405 - Release Date: 09/30/09 10:35:00
> No virus found in this outgoing message.
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091001/431872f6/attachment.vcf>
