[Qgis-user] Re: osgeo installer windows plugin installer
mtnbiketrail at zzz.com
Sun Oct 4 12:54:57 PDT 2009
I uninstalled everything, deleted the directories, and ran Osgeo4Win again with unstable QGIS for 1.3 version install.
original problem:
I updated 1.02 to 1.02.2, and then it would crash upon opening. I tried to revert and then I could not get the "plugin Installer" in the menu. I had it before the upgrade.
Thanks,
Tom
Message: 4
Date: Sat, 3 Oct 2009 20:54:54 +0200
Subject: Re: [Qgis-user] Re: osgeo installer windows plugin installer
To: qgis-user at lists.osgeo.org
Message-ID: <200910032054.54710.borysiasty at aster.pl>
Content-Type: Text/Plain; charset="utf-8"
Dne sobota 03 Å™Ãjna 2009 20:45:46 mtnbiketrail at zzz.com napsal(a):
> > So the plugin installer does not show in the QGIS menu, Windows XP.
> > There is no information on how to install the plugin installer. I can
> > download the zip file from the qgis website, but there is no information
> > on what to do with it. QGIS 1.02. I searched the forum with no results.
> > Installed via online osgeo installer.
Hi, there is no need to install any zip manually. First, check if there is the
plugin installer available on the plugin list in menu Plugins -> Manage
Plugins (the installer is a plugin too).
If not, it means you have no python support installed. Go back to the
Osgeo4win installer, advandced mode and ensure you have the 'qgis-python'
component installed (in the 'libraries' category). It should help.
B.
