[Qgis-user] Identify features across multiple layers.
Jürgen E. Fischer jef at norbit.de
Tue Oct 6 13:09:08 PDT 2009
Hi Micha,
On Tue, 06. Oct 2009 at 20:49:03 +0200, Micha Silver wrote:
> Among the release notes for 1.3.0 the new improvement: "Identify
> features across multiple layers" is listed.  I can't figure out what
> this means or how it works. Can someone enlighten me?
Go to the map tools tab in QGIS options dialog and switch the identify mode
from "Current layer" to "Top down".    After that you'll get features from
multiple layers, when you uses the identify tool.
You can also select (actually you block) the layers you want identify to work
on in the "identifiable layers" tab in the project options.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-20
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
