[Qgis-user] Allow smaller width(s) for the undo/redo panel
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Oct 7 22:53:32 PDT 2009
Nikos Alexandris:
> > Please, is it possible to change (and allow) smaller width(s) of the
> > undo/redo plugin? When it happens to work with a small monitor I want to
> > give less space to the layer/overview panel(s) but the undo/redo panel
> > (when present) is on the way!
> > Should I file a ticket?
On Sun, 2009-10-04 at 22:53 +0200, Tim Sutton:
> I reduced the minimum size from 354 to 200px in trunk revision 11756.
> (ie. will be available to you in upcoming QGIS 1.4 unless you are
> building from svn yourself).
> For me 200px provides a comfortable minimum size now.
> Regards
> Tim
Indeed, looks much better now. Thank you Tim!
Nikos
