[Qgis-user] HELP!! DLL not found when importing qgis.core and	qgis.gui
    Echavarria Gregory, Maria Angelica
    m.echavarriagregory at umiami.edu
    Thu Oct  8 08:22:05 PDT 2009
Dear QGIS group,
I have my application designed in PyQt and need to add a Qgis canvas to it. I followed the user guide ch. 12 to add things and convert my app into a PyQGIS application. Everything used to work fine in my PyQt4 and
PyWin32 installation. Last night I installed the binaries of QGIS, then added the recommended environment variables (PATH, PYTHONPATH, QGISHOME) to my system, and now this is what my Pythonwin editor complaints about:
>>> import qgis
>>> import PyQt4
>>> from qgis.core import *
  File "<interactive input>", line 1, in <module>
ImportError: DLL load failed: The specified module could not be found.
>>> from qgis.gui import *
>>> from PyQt4.QtCore import *
ImportError: DLL load failed: The specified procedure could not be found.
I think the DLL existed before the QGIS installation because the PyQt4.QtCore install used to work perfect!!. Also seems to be the exact same DLL what is missing in both cases (PyQt and QGIS imports). Could someone give me a hand with this? I'M STUCKED!!! If you happen to know which is the missing DLL, could you please email it to me along with the location?
Maybe it has something to do with the environmet variables?
Could it be because Python is also inside the binary distribution and I'm using my usual 'alone' installation? Or is it Windows?
Thanks very much,
Angelica
M. Angelica Echavarria-Gregory,
Ph.D Candidate
University of Miami
