[Qgis-user] Unable to start QGIS on windows
Jürgen E. Fischer
jef at norbit.de
Fri Oct 9 06:35:25 PDT 2009
Hi Carlos,
On Fri, 09. Oct 2009 at 15:32:15 +0200, Carlos Dávila wrote:
> I have installed 1.3 using standalone installer in several windows
> machines and in most of them it works fine, but I have two with XP Home
> Edition SP2 where I only get the following message when I try to open
> QGIS:
>From the download page:
> Note: You may need to install the Microsoft C Runtime Libraries too. If QGIS
> does not start, get the MSVC libs from here[1] and install them before trying to
> run QGIS again.
Might that be the problem?
Jürgen
[1] http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf&displaylang=en
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-20
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
