[Qgis-user] relative paths for texture graphics
    Goyo
    goyodiaz at gmail.com
    Sat Oct 10 12:20:09 PDT 2009
Hi John,
with the osgeo4w installer you can install recent builds of trunk that
work pretty well (I'm using them regularly at work) and simultaneously
previous versions. They are also compatible with versions installed with
the instandalone installer.
Just be aware that switching between versions can mess your
configuration or cause crashes due to incompatible plugins since they
share the configuration directory and registry entries (but this never
happened to me switching between 1.3 and trunk).
Goyo
El vie, 09-10-2009 a las 13:24 -0400, John Callahan escribió:
> Thanks.  Are there development builds available for download?  (I'm
> using Windows.)
> Or, should I uninstall the version I'm using now (1.3.0 Mimas,
> r11638.), then check out the latest via svn, build it (instructions at
> https://svn.osgeo.org/qgis/trunk/qgis/INSTALL) and go with that?
> (sorry, I have little experience in this area.)
> - John
> John Callahan, Geospatial Application Developer
> Delaware Geological Survey, University of Delaware
> Email: john.callahan at udel.edu
> Jürgen E. Fischer wrote:
> > Hi John,
> > On Fri, 09. Oct 2009 at 11:08:29 -0400, John Callahan wrote:
> > > Does QGIS support relative paths for texture fill graphics in the
> > > symbology?   In the qgis and qml files, I see the texturepath element
> > > that points to the graphic image file.
> > Try r11785.
> > Jürgen
> Qgis-user mailing list
