[Qgis-user] Problem adding attribute value for a new feature...
luca_manganelli at comune.trento.it
Wed Oct 14 07:45:47 PDT 2009
Hi to all, I'm using QGIS 1.3.0 and I have a problem setting an attribute
value to a postgis layer. I post the code:
ist = QgsMapLayerRegistry.instance()
# search for layer "test" in the list...
for name in ist.mapLayers():
lay = ist.mapLayer (name)
if (lay.name() == "testPostGIS"):
# obtain the columnId of the field...
columnIdx = lay.dataProvider().fieldNameIndex ("testCol")
# start editing... and then create new feature
lay.startEditing()
feat = QgsFeature()
feat.setGeometry (QgsGeometry.fromPoint(myPoint))
# this below doesn't update value ...
r = feat.addAttribute( columnIdx, QVariant(selTotem) )
lay.addFeature (feat)
lay.commitChanges ()
I see the point on the map, but the field value is still NULL. Why?
