[Qgis-user] how to size a vector layer polygon
Fred LaPlante
flaplante at flos-inc.com
Wed Oct 21 10:16:21 PDT 2009
Thanks for the suggestion Borys.
Sorry, but qgsAffine plugin seems to only rotate or translate entire polygon.
I need to be able to adjust a single side at a time to a specific length.
"OpenJump" does it nicely, showing the direction and length (at the bottom of the screen) of each line segment as you draw it out. As I recall "Azimuth & Distance" plugin would do the same.
Fred LaPlante
> Dne nedÄ›le 18 Å™Ãjna 2009 22:56:41 Fred LaPlante napsal(a):
>> > Is there some plugin I have overlooked? I know there used to be an
>> > Azimuth and Distance (v. 0.3) plug-in, but that now shows up as
>> > incompatible with qGIS1.3.
> Wow, where's that plugin?
> I hope qgsAffine plugin could help you. It seems to work with trunk. Please test
> it on a copy of your real data because it changes the working layer.
