[Qgis-user] Re: Layouter: different datasets in different frames -- creating insets
Marco Hugentobler
marco at hugis.net
Fri Oct 23 12:26:43 PDT 2009
Hi Rob
You may use the checkbox 'keep layer list' of the composer map widgets for
this:
-Load all the data into QGIS
- Set the layers for map1 visible, go to the composer, add the first composer
map and check 'keep layer list'
- Go back to the main map, set the layers for map2 visible and all others
visible. The layers in composermap 1 will remain as long as they are in the
layer list
- Go to the composer and add the second composer map. The second map will now
show layer set 2 while the first one keeps its layers.
Hope it works,
Marco
Am Freitag, 23. Oktober 2009 19.03:32 schrieb InterRob:
> Forgot to attach the image. Herewith.
> Rob
> 2009/10/23 InterRob <rob.marjot at gmail.com>
> > Dear list,
> > I find QGIS a very promising package to do real sophisticated GIS
> > analyses and cartography. Regarding that last bit, I have a practical
> > question: how can I add an "inset map" next to a frame featuring a
> > detailed map of a certain area. I managed to insert two frames with the
> > same contents, but different zoom levels (as illustrated by the attached
> > GIF-image). However, I wish to use different data in each of the
> > frames... How can I do this?
> > And how about inserting the frame extends (the indicating box in the
> > overview inset map)?
> > Regards,
> > Rob
Dr. Marco Hugentobler
HUGIS - GIS programming and consulting
Honrainweg 5
CH-8038 Zürich
marco at hugis.net
http://homepage.hispeed.ch/hugis/
