[Qgis-user] Re: Layouter: different datasets in different frames -- creating insets
InterRob rob.marjot at gmail.com
Mon Oct 26 05:14:49 PDT 2009
Thanks! I will give this a try and report back!
Rob
2009/10/23 Marco Hugentobler <marco at hugis.net>
> Hi Rob
> You may use the checkbox 'keep layer list' of the composer map widgets for
> this:
> -Load all the data into QGIS
> - Set the layers for map1 visible, go to the composer, add the first
> composer
> map and check 'keep layer list'
> - Go back to the main map, set the layers for map2 visible and all others
> visible. The layers in composermap 1 will remain as long as they are in the
> layer list
> - Go to the composer and add the second composer map. The second map will
> now
> show layer set 2 while the first one keeps its layers.
> Hope it works,
> Marco
> Am Freitag, 23. Oktober 2009 19.03:32 schrieb InterRob:
> > Forgot to attach the image. Herewith.
> > Rob
> > 2009/10/23 InterRob <rob.marjot at gmail.com>
> > > Dear list,
> > > I find QGIS a very promising package to do real sophisticated GIS
> > > analyses and cartography. Regarding that last bit, I have a practical
> > > question: how can I add an "inset map" next to a frame featuring a
> > > detailed map of a certain area. I managed to insert two frames with the
> > > same contents, but different zoom levels (as illustrated by the
> attached
> > > GIF-image). However, I wish to use different data in each of the
> > > frames... How can I do this?
> > > And how about inserting the frame extends (the indicating box in the
> > > overview inset map)?
> > > Regards,
> > > Rob
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Honrainweg 5
> CH-8038 Zürich
> marco at hugis.net
> http://homepage.hispeed.ch/hugis/
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091026/357b9313/attachment.html>
