[Qgis-user] wg84 projection problem
Werner Macho
werner.macho at gmail.com
Thu Oct 29 01:53:01 PDT 2009
sorry - forgot to write .. daphnis on windows - so it seems i'm pretty
out of date here @work ..
my fault .. sorry sorry sorry ..
didn't take a look at the start screen ..
to busy ;)
regards
Werner
> On Thu, 29 Oct 2009 09:37:18 +0100
> Werner Macho <werner.macho at gmail.com> wrote:
>> hi all
>> regarding setting b)
>> why is there a double entry of WGS84 in the Ellipsoid for distance
>> calculation? One at the top and one at the bottom ..
> my svn version from last week does include WGS 60, WGS 66, WGS 72, WGS 84 -
> but none of them is duplicated. -> ?
>> bug? feature?
>> greetings
>> Werner
>>> you have to define:
>>> a) settings => project properties => general => layer units (select
>>> meters)
>>> b) settings => options => map tools => ellipsoid for distance calculation
>>> to fit the ellipsoid used in your CRS.
