[Qgis-user] wg84 projection problem
Werner Macho
werner.macho at gmail.com
Thu Oct 29 01:59:55 PDT 2009
Hi!
Installed Mimas on Windows here -> problem confirmed .. two WGS84 to
select at "Settings -> Options -> Map tools -> Ellipsoid for distance
calculations"
One WGS84 directly at the top to select - the other one at the bottom
above Walbeck ellipsoid.
Probably already solved in SVN .. As I don't have a SVN version here I
can only use prepared ..
Thx for confirming Flavio - I'll take a look at SVN-Version as soon as
I'm back home again
regards
Werner
> 2009/10/29 Werner Macho <werner.macho at gmail.com
> <mailto:werner.macho at gmail.com>>
> hi all
> regarding setting b)
> why is there a double entry of WGS84 in the Ellipsoid for distance
> calculation? One at the top and one at the bottom ..
> bug? feature?
> I confirm: in my 1.3 mimas (on Debian) WGS84 is duplicated. One on the
> top adn another one on the bottom of the list
> greetings
> flavio
> Linux, perche' no? Io uso debian.
