[Qgis-user] Qgis and Grass bug after crash
Giovanni Manghi giovanni.manghi at gmail.com
Thu Oct 29 03:20:51 PDT 2009
did you check if you have a .gislock file? If yes try delete it.
cheers
-- Giovanni --
PS
Please upgrade to 1.3, there were many updates in the grass toolbox
since 1.0.2
On Thu, 2009-10-29 at 10:15 +0000, Michiel Kunzel wrote:
> Hello everyone,
> I am new to QGIS (using 1.0.2 Mimas on Windows Vista) and have
> encountered a problem.
> I was working with the grass toolbox from QGIS when the program
> crashed. Upon re-opening the program QGIS showed that the GRASS MAPSET
> I was using was still active.
> Now I need to switch to another MAPSET but the program will not let
> me. The close-MAPSET button is not useable and the GRASS toolbox is
> also not active, so I can't work on my mapset in QGIS anymore.
> Is there a solution for this? Might be I overlooked something.
> Thanks in advance,
> Michiel Künzel
> ______________________________________________________________________
> Windows 7: It helps you do more. Explore Windows 7.
> Qgis-user mailing list
