R: Re: [Qgis-user] problems with opening raster files
alessandro.sarretta at inwind.it
Thu Oct 29 03:40:00 PDT 2009
Ok, solved in the same way. Thanks!
I noticed that the problem is the gdal-python library I installed to play with Image Clipper and Image Cutter... With this library I have the "raster problems", without it no problems.
Someone understands if it is a bug of this library?
ciao
Ale
----Messaggio originale---- Da: giohappy at gmail.com Data: 29/10/2009 11.19 A: "alessandro.sarretta at inwind.it"<alessandro.sarretta at inwind.it> Cc: <qgis-user at lists.osgeo.org> Ogg: Re: [Qgis-user] problems with opening raster files Hi Alessandro. I had the same issue. I don't know what caused it but a fresh install (with gdal16 and qgis 1.4.x) of the whole stack solved it. Not an elegant solution, but it works :)giovanni
2009/10/29 alessandro.sarretta at inwind.it <alessandro.sarretta at inwind.it>
Hi all, I encountered a problem with QGIS installed from osgeo4w, Windows XP. I can't open any raster (I tried with geotiff, asc, ESRI adf...) and the message is always: xxx "is not a supported raster data source". The only option i have in the dropdown list in the "Open a GDAL Supported Raster Data Source" window is "Grass and all other files (*)". This happens with QGIS 1.4.0 trunk, as with 1.1.0 and 1.0.2. I think that this problem could be related to the installed gdal library (gdal 1.5.4-4), but really I don't know... Suggestions? thanks Ale _______________________________________________ Qgis-user mailing list Qgis-user at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20091029/d5b98f88/attachment.html>
