[Qgis-user] SDA4PP
Giovanni Manghi giovanni.manghi at gmail.com
Fri Oct 30 02:44:11 PDT 2009
the message is pretty clear, after having installed R you need to add to
the "path" environment variable the location where the R binaries are
located.
cheers
-- Giovanni --
On Fri, 2009-10-30 at 09:28 +0100, marcozanieri at geosweb.it wrote:
> Hi, I tried to install the plugin in Qgis 1.3, but when i
> finish the intallation i riceve this error: "Unable to
> determine R version from the registery .Calling the command
> 'R RHOME' does not return anything. This might be because
> R.exe is nowhere in your Path."
> Thanks all!
> Marco Zanieri
> Qgis-user mailing list
