[Qgis-user] GSSAPI Support under OSX
William Kyngesburye
woklist at kyngchaos.com
Wed Apr 7 06:54:02 PDT 2010
Qgis and pgadmin3 use separate copies of libpq, but you are still probably right. I know I don't build my Postgres GSSAPI - it doesn't appear to be a default-on configure option, and I never bothered to look into what it is. Very likely whoever built the Mac version of pgadmin3 did the same with their libpq.
I do include Kerberos, which appears to be related. I could easily add GSSAPI in my next Postgres build (I see 8.4.3 is out, so it should be soon), though it will probably only appear in my Qgis dev builds and not 1.4.
On Apr 7, 2010, at 7:37 AM, Garbin, David wrote:
> I am trying to access a PostgreSQL 8.4 database on a remote LINUX server with Kerberos 5 tickets using GSSAPI. This works from a Windows version of QGIS , but the OSX binary version gives a “GSSAPI Authentication not supported” error. A binary download of pgamin3 also gives the same error, so I suspect a common libpq problem. GSSAPI authentication is working fine for SSH clients on the same machine.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that the past isn't a fiction designed to account for the discrepancy between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
