[Qgis-user] Complete information of a point created automatically.
Patrice Vetsel
ubuntu at kagou.fr
Thu Apr 8 08:13:58 PDT 2010
Le jeudi 08 avril 2010 à 16:13 +0200, Patrice Vetsel a écrit :
> Le jeudi 08 avril 2010 à 11:49 +0200, Patrice Vetsel a écrit :
> > Le jeudi 08 avril 2010 à 00:58 +0200, Goyo a écrit :
> > > El mié, 07-04-2010 a las 12:02 +0200, Patrice Vetsel escribió:
> > > > I want to use Qgis in situation on the ground. Using a plugin to center
> > > > a map dynamically connected to my gps. My problem is that the creation
> > > > of points on a shapefile layer is very restrictive if you want to fill
> > > > at the same time, the information (1500 points to be created). The idea
> > > > is to have a configurable plugin, which will, after selecting a type,
> > > > fill in items automatically.
> > > > The information is rather repetitive and rather simple. These are street
> > > > lights and often they are the same. Power, nature of bulbs, I'd have to
> > > > input every time. The best would be that the ID is automatically
> > > > incremented and I can select a type (Power 100W/Nature Sodium). After
> > > > selection by clicking on the map to add as many points as you want, and
> > > > the ID field is incremented and power / 100W/Sodium nature are made.
> > > > Have you any ideas?
> > > You can use custom forms (and maybe python):
> > > http://linfiniti.com/2009/11/creating-dynamic-forms-a-new-feature-headed-for-qgis-1-4/
> > Wow. It's very interesting. Thanks.
> > I manage to make basic. But I can not get more convenient. I tried to
> > create a set of checkbox. I used a GroupBox and I added 2 RadioButton
> > inside. But in the end it does not work. I did not find either how to
> > display a combo pre-filled.
> In fact I'v found also QComboBox, setting it's name the same as in
> shapefile, adding some values in QComboBox but this is not working
> too :(
I attach a test.ui
> > Regards
> > Patrice Vetsel
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
Type: application/x-designer
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100408/e0e295eb/attachment.bin>
