[Qgis-user] Problem with adding GeoTIFF raster
Micha Silver
micha at arava.co.il
Sun Apr 11 11:46:31 PDT 2010
Kieron Dunbar wrote:
> I tried to import one of the GeoTIFF rasters from
> www.ordnancesurvey.gov.uk into QGis, but it seems to ignore the
> co-ordinates reported by gdalinfo, as it puts the top left corner at
> 0,0 with a scale of 1 pixel per unit. Is there a way I can put this
> file in the correct position? I haven't used QGis or GDAL before, so I
> apologise if I have missed something obvious?
> The properties gdalinfo reports are as follows (slightly abbreviated):
> Driver: GTiff/GeoTIFF
> Files: 1 250 000 Scale Raster/data/HP.tif
> Size is 4000, 4000
> Coordinate System is `'
Here's the problem ^^^^
After unzipping the downloaded file, if you look in the directory "data"
there's another directory "georeferencing files". There you'll find the
*.tfw (world files) for each of the the *tif files. It's strange that
they are delivered in a separate directory. Just copy all the *.tfw
files into the same dir as the *.tif files, and they'll be positioned
correctly.
One additional note: When you load the layers into QGIS, be sure to
choose the "National Grid" as the CRS. That's EPSG:27700.
> Metadata:
> TIFFTAG_IMAGEDESCRIPTION=1:250 000 TILE HP.TIF
> TIFFTAG_DATETIME=2009:05:01 08:32:51
> TIFFTAG_COPYRIGHT=ORDNANCE SURVEY CROWN COPYRIGHT 2009
> TIFFTAG_XRESOLUTION=254
> TIFFTAG_YRESOLUTION=254
> TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
> COMPRESSION=LZW
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 4000.0)
> Upper Right ( 4000.0, 0.0)
> Lower Right ( 4000.0, 4000.0)
> Center ( 2000.0, 2000.0)
> Band 1 Block=4000x65 Type=Byte, ColorInterp=Palette
> Color Table (RGB with 256 entries)
> 0: 59,43,48,255
> 255: 253,252,252,255
> Many thanks.
> Kieron Dunbar
> Qgis-user mailing list
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
