[Qgis-user] Map Composer
Andreas Neumann a.neumann at carto.net
Wed Apr 14 12:07:54 PDT 2010
yes - you can have several map items in one layout and also place them
on top of each other. Each map item can have it's own map extent/scale
and you can lock the layer list, by pressing the "Lock layers for map
item" to prevent live updates from the main project window.
I would recommend using the latest trunk version, but the 1.4 may have
this option already.
Andreas
On 4/14/10 7:02 PM, Kumaran Narayanaswamy wrote:
> In the current version when we do Map Composer is there a way where we
> can show a frame with global map with an inset to the area of interest
> and another frame which has the actual area of interest? Is this
> possible in the current 1.4.0 or the trunk version?
> Regards
> Kumaran
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100414/980e7dfc/attachment.html>
