[Qgis-user] limits of delimited text plugin
Alex Mandel tech_dev at wildintellect.com
Thu Apr 22 00:35:51 PDT 2010
maning sambale wrote:
> Hi,
> I am importing the GNS names textfile in to a point vector.  Th etext
> file has 117,000 lines  using the delimited text plugin I was able to
> import on 81,665.  Is there a limit to the number of records we can
> import with the delimited txt plugin?
I seem to recall someone I know running into this last year, and we got
around it by just importing the text to postgis and then turning it into
a spatial layer with a query. You could also do this with spatialite now.
Also, ogr2ogr command line could be used but is a little confusing
sometimes for csv.
Alex
