[Qgis-user] Fwd: Discrepancy between value tool, spectral profile and Point sampling tool for large data sets (2)
M.E.Dodd
m.e.dodd at open.ac.uk
Thu Dec 2 08:04:58 PST 2010
Would be very helpful if point sampling tool (and the others?) would report where they are getting the data from rather than just giving a column of numbers. So for example they would give the lat long or other coordinate value then the value 228 etc. when I've done tests with datasets containing a few thousand numbers the output sequence is the same as the input sequence (as it should be) but without the coordinates its just a matter of hoping?
-----Original Message-----
From: Agustin Lobo [mailto:alobolistas at gmail.com]
Sent: 02 December 2010 15:59
To: qgis-user; qgis-developer
Subject: [Qgis-user] Fwd: Discrepancy between value tool, spectral profile and Point sampling tool for large data sets (2)
FYI
Illustration:
https://sites.google.com/site/openfiles2/home/valuetoolproblem2.jpeg
Test data:
https://sites.google.com/site/openfiles2/home/samplingtoolproblem.zip
Agus
---------- Forwarded message ----------
Date: 2010/12/2
Subject: Discrepancy between value tool, spectral profile and Point
To: Ghislain Picard <ghislain.picard at lgge.obs.ujf-grenoble.fr>,
fidel at centrogeo.org.mx, borys at wolf.most.org.pl, alobolistas at gmail.com
> Hi!
> I've found that value tool reports values in a different order than spectral profile and Point Sampling tool
> for very large data sets (this one 72 layers). See in the attachment
> the value of the first band, for example, in Value tool (118), while spectral profile and the values for that point extracted by Point Sampling Tool are different.
> The sequence 228, 225, 248 ... in Value tool starts in layer 50
> I've checked in R (where the file is made) and Value Tool is right.
> The most confusing is that a 3-band raster made with the first 3 bands
> works the same for all 3 tools: 118, 243, 236
> I'm trying to make a little 3x3x72 raster for testing and will report to
> qgis lists as well.
> Agus
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
The Open University is incorporated by Royal Charter (RC 000391), an exempt charity in England & Wales and a charity registered in Scotland (SC 038302).
