[Qgis-user] mapserver
Lionel Roubeyrie
lionel.roubeyrie at gmail.com
Mon Dec 6 02:04:29 PST 2010
Ok, I understand my mistake between qgis-mapserv and mapserv, but I
can't have a map rendered with both...
So, I have saved a qgis project file containing only one postgis layer
under a directory "world" under /usr/lib/cgi-bin, and copied inside
the qgis_mapserv.fcgi and wms_metadata.xml files. Calling
http://localhost/cgi-bin/world/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
gives a xml file with good values, but
http://localhost/cgi-bin/world/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=499353,6421022,686146,6600023&CRS=EPSG:2154&WIDTH=1024&HEIGHT=768&LAYERS=ALL&STYLES=,,&FORMAT=image/jpeg&DPI=96
results in a blank page, and exporting the same project to a .map file
with the mapserver export plugin and calling the given url gives the
same result.
The cgi-bin directive :
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Options +ExecCGI -Includes -MultiViews +SymLinksIfOwnerMatch
SetEnv LIBRARY_PATH /usr/lib/qt4:/usr/lib/qgis
Order allow,deny
Allow from all
</Directory>
What do I have to change/append?
Thanks
2010/12/4 Giovanni Manghi <giovanni.manghi at gmail.com>:
> On Sat, 2010-12-04 at 14:12 +0100, Lionel Roubeyrie wrote:
>> shp2img
> isn't shp2img a mapserver only utility?
> cheers
> -- Giovanni --
Lionel Roubeyrie
http://youarealegend.blogspot.com
