[Qgis-user] Ideas for an intro to QGIS for beginners (mostly wildlife ecologists and conservationists)
Noli Sicad
nsicad at gmail.com
Wed Dec 15 04:08:04 PST 2010
Maning,
The New "create custom db queries" plugin for Spatialite and Postgis
is very cool plugin to demonstrate.
Try to queries e.g. "Select * from birds-pop < 5 ". The query will
display the polygons which satisfy the conditions in the TOC.
Do some cool stuff like distance buffering of stream and rivers for
conservation and replanting areas for native tree species using this
plugin. The beauty of the plugin is dynamic render the results in the
TOC - mapcanvas.
Noli
On 12/15/10, Noli Sicad <nsicad at gmail.com> wrote:
> Maning,
> HomeRange plugin for animal movement analysis would be probably good.
> http://www.qgis.org/wiki/HomeRange_plugin
> http://www.osgeo.org/pipermail//soc/2008-September/000459.html
> Noli
> On 12/15/10, Giovanni Manghi <giovanni.manghi at gmail.com> wrote:
>> Hi Maning,
>> wildlife biologist and conservationists here! ;)
>> I would suggest you to show also the gps tools (downloading/uploading
>> waypoints/tracks from gps units) and the live gps tracking.
>> cheers
>> -- Giovanni --
>> On Wed, 2010-12-15 at 19:24 +0800, maning sambale wrote:
>>> Hi,
>>> I am requested to present and conduct a brief workshop (3 hours) to a
>>> symposium mostly composed of wildlife ecologists and conservationists.
>>> My initial plan is to:
>>> - present basic qgis interface
>>> - create simple point data (from sampling transect plots using
>>> delimited text plugin)
>>> - create map layouts (map composer) and simple webmaps (openlayers
>>> plugin)
>>> - promote foss-geo philosophies (along the side)
>>> I am aware that some users here are on a similar field (wildlife
>>> ecology and conservation), I am posting to collect more ideas on what
>>> specific exercises I should prepare for these audience.
>>> Advance thanks!
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
