[Qgis-user] Re: Fix polygon that is not closed?
Andrea Peri aperi2007 at gmail.com
Sat Dec 18 03:12:21 PST 2010
>and I was unable to
>visually find where is this topological error...
I add another hint:
OpenJump has a wonderful topological test that report you exactly the vertex
where is all the error.
Regards,
Andrea.
2010/12/17 Zoran Jankovic <zoran.jankovic at zisis.hr>
> On Fri, Dec 17, 2010 at 12:55 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> >Yes, and QGIS displays the shapefile with no problem, and I was unable to
>> >visually find where is this topological error... But, nevertheless, PostGIS
>> >refuses to import it, and geometry validity check says its not closed :-(...
>> What version of postgis ?
>> I think the last version of postgis allow to load Unvalid Polygon. (1.5.1+)
>> Surely the actula trunk version (2.0.0) has a ST_MakeValid(..) to correct
>> the self-intersections.
>> Regards,
> Ah, an eye opening comment indeed :-). I realized I was using SPIT plugin,
> when I had the more advance shp2pgsql at hand... I am actually using PostGIS
> 2.0 from SVN, so I was able to import those shp with no problem... ...for
> now... :-)
>> Andrea Peri
>> qwerty àèìòù
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20101218/a1f00a1d/attachment.html>
