[Qgis-user] custom db query plugin update
    Noli Sicad
    nsicad at gmail.com
    Sun Dec 19 18:29:10 PST 2010
Hi Ricardo,
Thanks for updating the plugin.
However, I still have problem. I think it is the Qgis 1.7 trunk
version r14914M Ubuntu 10.04.. My spatial manager does not recognized
the spatialite tables as well.
What version of QGIS are you using in Ubuntu 10.04 that this plugin works?
Thanks.
Noli
On 12/20/10, Ricardo Filipe Soares Garcia da
<ricardo.garcia.silva at gmail.com> wrote:
> Hi all
> I uploaded a new version (v0.5) of the 'Custom db query' plugin.
> It is marked as 'experimental' and it should be treated as so by users
> that decide on downloading it ;)
> Improvements over the previous version:
> - There is now a shortcut key (Alt+x) for executing SQL queries
> - The default geometry and identifier column names for SpatiaLite are
> now 'Geometry' and 'PK_UID'
> - I added an 'Inspect tables' tab, so that it is possible to see the
> table's and column's names and also their data
> - I made some changes, towards supporting utf-8 databases, but I'm not
> sure if it is 100% all right
> Some of the plugin's shortcomings, that I hope to fix in future versions:
> - There is no progress bar indicating that there is a query running
> - There is no way to cancel a running query
> - The plugin's help page is still pretty much unfinished, so there
> aren't many clues as to how to operate it
> I think I'll release next version when I can solve these pending
> issues. By that time I will drop the experimental mark.
> In the meanwhile I'll try to record some videos showing off the
> plugin's usage, while I overcome may laziness in writing a proper help
> page.
> If you decide to test it out, please leave me some feedback on this
> mailing-list, and, if possible, using this thread.
> Thank you
> ___________________________ ___ __
> Ricardo Garcia Silva
> Qgis-user mailing list
