[Qgis-user] Announce: MemoryLayerSaver plugin
Chris Crook ccrook at linz.govt.nz
Mon Dec 20 17:14:53 PST 2010
Hi
I've just uploaded a MemoryLayerSaver plugin to the contributed plugins on pyqgis.org.
This makes memory data provider layers (such as those generated by the contour plugin) persistant.  Each layer is saved alongside the project file in sqlite files.  When the project is reloaded the memory layer data gets repopulated as it was.  (Without the plugin the layer remains in the project, but all the data gets lost).
To use the plugin, simply install it.  Once installed all memory layers in all projects will be saved with the project, until you uninstall it again.
Cheers
Chris
______________________________________________________________________________________________________
This message contains information, which is confidential and may be subject to legal privilege.
If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
Thank you.
