[Qgis-user] Announce: MemoryLayerSaver plugin
Chris Crook
ccrook at linz.govt.nz
Tue Dec 21 09:05:04 PST 2010
Hi Ricardo
Thanks for this .. I think it is because I missed an "&" after the QgsAttributeIds in that line, id
QObject.connect(layer, SIGNAL("committedAttributesDeleted(const
QString &, const QgsAttributeIds &)"),self.setProjectDirty2)
Oddly, it worked fine on my version :-(
You could try editing the file and see if that fixes it. I'll upload an amended version now.
Cheers
Chris
________________________________________
From: Ricardo Filipe Soares Garcia da [ricardo.garcia.silva at gmail.com]
Sent: 22 December 2010 00:16
To: qgis-user
Subject: Re: [Qgis-user] Announce: MemoryLayerSaver plugin
Hi Chris
This plugin is a very nice idea, thanks for it!
I encountered the following error while testing out:
File "/home/geo2/.qgis/python/plugins/MemoryLayerSaver/MemoryLayerSaver.py",
line 40, in connectProvider
QString &, const QgsAttributeIds )"),self.setProjectDirty2)
TypeError: type 'QgsAttributeIds' is not supported as a slot argument type
In case it is relevant:
- I was testing it using the 'HighWays' spatialite layer, present in
the spatialite testing dataset [1]
- I was testing it against the 'Profile from line' plugin, that
generates temporary layers using the memory provider. This plugin is
in the QGIS contributed repository
- Iam using QGIS 1.6 as available in the ubuntugis-unstable ppa
Thank you
[1] - http://www.gaia-gis.it/spatialite/resources.html
On Tue, Dec 21, 2010 at 1:14 AM, Chris Crook <ccrook at linz.govt.nz> wrote:
> Hi
> I've just uploaded a MemoryLayerSaver plugin to the contributed plugins on pyqgis.org.
> This makes memory data provider layers (such as those generated by the contour plugin) persistant. Each layer is saved alongside the project file in sqlite files. When the project is reloaded the memory layer data gets repopulated as it was. (Without the plugin the layer remains in the project, but all the data gets lost).
> To use the plugin, simply install it. Once installed all memory layers in all projects will be saved with the project, until you uninstall it again.
> Cheers
> Chris
> ______________________________________________________________________________________________________
> This message contains information, which is confidential and may be subject to legal privilege.
> If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message.
> If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message.
> LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ.
> Thank you.
> Qgis-user mailing list
___________________________ ___ __
Ricardo Garcia Silva
Thank you.
