[Qgis-user] Installation issue QGIS 6.1.0
William Kyngesburye
woklist at kyngchaos.com
Thu Dec 23 12:09:00 PST 2010
plugin installer is also built into QGIS. Delete that from your home plugins.
On Dec 23, 2010, at 1:57 PM, Joao Pinelo wrote:
> Thank you guys, but no luck here.
> Find the folder, but not the file mentioned. Either I didn't understand which file it is, or I'm in the wrong folder. Sorry about this.
> Please see screen capture of my plugin installer folder. Thanks for your help. J
> <PastedGraphic-1.png>
> On 23 Dec 2010, at 19:23, William Kyngesburye wrote:
>> Note: to find it, open your home folder. Then select Go to Folder from the Go menu, and enter .qgis. From there it's easy to find the plugins folder.
>> On Dec 23, 2010, at 11:38 AM, Benoit wrote:
>>> Hi,
>>> Try to delete the gdal raster tools plugin from your home plugin folder. QGIS >=1.6 has this plugin installed in the qgis folder instead and this had caused a similar error on winxp.
>>> HTH,
>>> Benoit
>>> Sent from my iPod
>>> On 23 Dec 2010, at 17:56, Joao Pinelo <j.pinelo at mac.com> wrote:
>>>> Hi,
>>>> I'm having a plugin issue when installing new version. I guess it is due to having an old version.
>>>> Events:
>>>> Trashed QGIS 5.3.1
>>>> Installed GDAL complete 1.7 and GSL1.14-1 frameworks
>>>> Installed GRASS 6.4.app and FreeType Framework 2.4.2-2
>>>> Installed latest version QGis1.6.0
>>>> Result:
>>>> On opening QGIS get notice:
>>>> "The Plugin Installer has detected an obsolete plugin which masks a newer version shipped with this QGIS version. This is likely due to files associated with a previous installation of QGIS. Please use the Plugin Installer to remove that older plugin in order to unmask the newer version shipped with this copy of QGIS."
>>>> Question:
>>>> Any idea how can I get rid of this obsolete plugin?
>>>> Many thanks
>>>> Joao
>>>> mac OS 10.6.5
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"I ache, therefore I am. Or in my case - I am, therefore I ache."
- Marvin
