[Qgis-user] Standalone-App with QGis-Libraries
Albin Blaschka
albin.blaschka at standortsanalyse.net
Wed Dec 29 12:09:20 PST 2010
On 2010-12-29 20:40, Germán Carrillo wrote:
> I think you just need to set the qgis_prefix variable this way:
> qgis_prefix = "/usr"
> Regards,
> Germán
Hello!
Bingo! Before starting the demo-app doing a "export QGISHOME=/usr" on
the console did it! Thanks a lot! Now, on the next steps... :)
best wishes from Austria,
Albin
| Albin Blaschka, Mag.rer.nat.
| Etrichstrasse 26, A-5020 Salzburg
| * www.albinblaschka.info * www.thinkanimal.info *
| - It's hard to live in the mountains, hard but not hopeless!
> 2010/12/29 Albin Blaschka <albin.blaschka at standortsanalyse.net
> <mailto:albin.blaschka at standortsanalyse.net>>
> Hello!
> I just started to experiment for writing a stand-alone app based on
> the QGIS-Libraries and Python, following the example
> http://desktopgisbook.com/Creating_a_Standalone_GIS_Application_1
> and the PyQGIS Developer Cookbook
> Based on the Starting Kit for a plugin and on the
> QGIS-Python-Console, everthing is working as expected, but the
> example for the Standalone-App I just get "Failed to load" when I
> want to load a shapefile (the window and the dialog open fine),
> which otherwise as noted above loads just fine...
> I get no other error message as the "failed to load"...
> (I am using the downloaded version of the Shapeviewer-Demo-App, I
> have it attached)
> I am on Kubuntu 10.04.1, Lucid Lynx,
> QGIS (1.6) and related stuff installed from
> http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu lucid main
> PYTHONPATH=/usr/share/qgis/python
> Python 2.6.5 (r265:79063, Apr 16 2010, 13:57:41)
> What am I missing?
> I tried from the Python-Console from within QGIS (where everthing
> works) to print PYTHONPATH, but did only get "None" (with print
> os.getenv("PYTHONPATH"))
> I am also a Python-Newbie, btw...
> Thank you in advance...
> Albin
> | * www.albinblaschka.info <http://www.albinblaschka.info> *
> www.thinkanimal.info <http://www.thinkanimal.info> *
