[Qgis-user] Qgis and sqlite
    Peter Ersts
    ersts at amnh.org
    Fri Feb  5 11:42:10 PST 2010
Pedro,
Check out the eVis plugin. It has the ability to connect to SQLite
databases using Qt's library so you don't have to have spatialite. It
basically does exactly what John just mentioned and allows you to enter
full SQL statements as well. The only downside is that the layers eVis
creates are not persistent, so you should not save them in your project
unless you convert them to a persistent format like a shapefile.
-pete
On 02/05/2010 02:33 PM, John C. Tull wrote:
> Hi Pedro,
> My best guess is you will need to dump the table to a text file, then use the delimited text layer plugin to bring it into qgis. I don't think there is any direct interaction with sqlite in the absence of making use of spatialite. Others can correct if wrong.
> Regards,
> John
> On Feb 5, 2010, at 10:28 AM, ptg at clix.pt wrote:
>> Hi
>> Is it possible to open a sqlite database in qgis and project points based on two fields (lat, long) of the database without spatialite?
>> Thank you
>> Pedro
Peter J. Ersts, Software Developer
American Museum of Natural History
Center for Biodiversity and Conservation
Central Park West at 79th Street
New York, New York 10024
Web: http://biodiversityinformatics.amnh.org
Web: http://cbc.amnh.org
Open Source,
...evolving through community cooperation to change the world bit by bit
Quantum GIS Raster Development Team.
