[Qgis-user] HELP! Search Query Builder has limited operators
badaveil
badaveil at gmail.com
Mon Feb 8 06:10:45 PST 2010
Dr. Thank you again for a fast reply.
I open a map, then open the attribute table, yes, I see the field
calculator, however, only the first 4 icons on the left until the magnifine
glass are active, the rest including the field calculator are not active.
How do I activate it? So close but yet so far.
Abbas
On 8 February 2010 16:17, Marco Hugentobler <marco at hugis.net> wrote:
> Hi Abbas
> Use the field calculator (calculator button in the attribute table). There
> you
> have an area button and you may create a field with the feature area with
> it
> (or use arithmetic expression that contain the feature area).
> Regards,
> Marco
> Am Montag, 8. Februar 2010 09.10:58 schrieb badaveil:
> > I want to calculate the areas of specific plots of land (polygon). In
> > Mapinfo, the Search Query Builder has an "area" operator to help to do
> > this. However in QGIS, this basic function is missing and I am lost.
> > Please advice. Thanks
> > Abbas
> Dr. Marco Hugentobler
> HUGIS - GIS programming and consulting
> Webereistrasse 66
> CH-8134 Adliswil
> marco at hugis.net
> http://homepage.hispeed.ch/hugis
> Technical Advisor QGIS Project Steering Committee
http://badaveil.multiply.com
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100208/e5966c7b/attachment.html>
