[Qgis-user] export to mapserver
legio nostra
legio.patria at gmail.com
Wed Feb 10 02:29:33 PST 2010
Hello Richard
As you correctly guessed, i'm working with a windows client and i have a
linux server. Specifically in this case i'm using my friends gisvm server
(Ricardo Pinho, Portugal) and the server has a /mapas subdirectory that is a
symbolic link to /home/user/gisdata.
/home/user/gisdata is a samba shared subdirectory that I access from my
windows client as \\gisvmsrv\gisdata.
We assume we cant use the "windows samba url" because the final .map file is
going to reside in the linux server under /mapas.
Maybe its just a case of (manually) renaming the online_resource inside the
.map file to adjust for mapserver to find the file in the server.
Thanks,
Orlando
2010/2/8 Richard Duivenvoorde <richard at duif.net>
> Hi Orlando,
> the url's you see in the alert after the successfull generating of the
> mapfiles was intended to be a fast way of just testing the mapfile and view
> of it. Normally url's like this should be working, it's 'standard' checking
> stuff of mapserver, see http://mapserver.org/cgi/controls.html
> It's always better to check it via a real wms-client like QGIS, an
> OpenLayers client or gvsig.
> if it is not working, there are some things to check:
> 1) in the url of your mail of tody I see 'modo' this should be 'mode', but
> I think that is just a typo of you
> http://localhost/cgi-bin/mapserv?map=/mapas/toponimia.map&modo=map&layers=all
> should be
> http://localhost/cgi-bin/mapserv?map=/mapas/toponimia.map&mode=map&layers=all
> 2) Is http://localhost/cgi-bin/mapserv?map=/mapas/toponimia.map a valid
> url on your machine?
> 3) Is the mapfile /mapas/toponimia.map a valid path to your map?
> If both questions are true, what then do you see if you ask for the
> capabilities of this server?
> You are running linux isn't it?
> Another caveat for different findings with different clients is that there
> is not a valid mapserverurl in the 'ows_onlineresource' metadata of the
> mapfile. Lately most clients look for THAT url to do a getmap request. But
> older clients actually use the url (host/path) of the capabilities url you
> gave them.
> If you still have problems, please let us know (with as much info as
> possible: (OS, QGIS-version, mapfile, projectfile) it's always possible
> that you found a bug ...
> Regards,
> legio nostra wrote:
>> Hello everyone,
>> I am trying to export a map to the mapserver and I'm using qgis trunk.
>> After doing OK, it creates a file named "toponimia.map. Then I try to view
>> the map "via browser" and I see a blank page, while in
>> gvSIG 1.1.2 version, the map appears via browser.
>> What remains to be done to be able to view the map via browser window,
>> where I can see the files: symbols.txt and fonts.txt QGis
>> is supposed to create.
>> Thank you for your help
>> -- orlando bernardo --
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100210/6006fe63/attachment.html>
