[Qgis-user] Re: new georeferencer
Jean-Claude Repetto
jcrml at mxm.eu
Mon Feb 15 03:53:38 PST 2010
Dominique Legendre wrote :
> Hi Maxim
> I am trying
> http://svn.gis-lab.info/qgis-gdal-georef/libs/georefplugin_012710_074741.dll
> Great work!
> But I always have problem with opening standard 1.4 GCP file
> No error message, both during initial raster loading nor with Load GCP
> Points function, but nothing is loaded
> The structure of the files are different:
> original:
> mapX mapY pixelX pixelY
> 550000.000000000000000 122000.000000000000000 261.900271533560385
> -324.928624696051543
> with tab between fields
> new georeferencer:
> mapX,mapY,pixelX,pixelY,enable
> 550000.000000000000000,122000.000000000000000,261.060059317844548,-325.307107156587961,1
> so i modified the original file, changing tab to comma and adding enable on
> the title and ,1 on the other lines and after these changes, it 's working
> both during initial raster loading or with the Load GCP Points function.
> Sorry for re posting this request. Is it possible to add output pixel size
> during geocoding process (for future mosaicing)?
> Of cause, the GDAL script output help me a lot to do manually. Thanks ! this
> script output is really a good idea.
Hello Maxim,
I have tested the trunk version of the georeferencer plugin, and there
is still the same problem : it is not able to load GCP files written
with previous version of the plugin.
Regards,
Jean-Claude
