[Qgis-user] Problems with a projection, how to import an "el" tag in qgis
jamesmikedupont at googlemail.com
Thu Feb 18 12:37:31 PST 2010
I have two problems.
One is a shp file that should be kosovo, but is thousands of km away from
the osm data I imported
http://filebin.ca/wsvehh/municipalities.zip
here is the osm region
http://www.openstreetmap.org/?lat=42.57&lon=20.93&zoom=8&layers=B000FTF
Second is an elevation file I have,
There are parts 5,6,7,8 that are interesting
http://senduit.com/138b18
I have been able to merge them into one, and separate out all closed areas.
but there are partfor one there are ways that are split between files.
Is there a way to join the ways between the files? do I need to code that
myself?
I have started working on some perl scripts. But can qgis manage that? I
would like to make a colored elevation map with that, also to close off the
areas that are open.
please help,
thanks
mike
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100218/2b9f7f3c/attachment.html>
