[Qgis-user] WFS-Plugin: several questions
Stephan Holl
stephan.holl at intevation.de
Wed Feb 24 03:33:36 PST 2010
Hi Marco,
Marco Hugentobler <marco at hugis.net>, [20100224 - 10:36:35]
> Hi Stephan
> The WFS provider stores everything in virtual memory.
> > Are there any sort of indexing of the WFS-result-dataset?
> It uses a spatial index.
yes, thanks for clearing that.
> > Is there an option that only the features inside the BBOX of the
> > mapwindow are available? Ideally when panning the resultset will be
> > filled up so that already retrieved features do not fall out of the
> > attribute table anymore (OK, a little like AJAX-requests...)
> At the moment there is no such option.
> Something that would be straightforward to add is the option to use
> the current map extent as BBOX
yes, this would be first shot.
Can you give a rough estimation about the work to be needed to do that?
> (but this won't fill up the layer).
Hmm, seems even more difficult to solve this, but perhaps your dynamic
BBOX-adoption seems a good startingpoint.
Cheers
Stephan
> Am Mittwoch, 24. Februar 2010 10.15:17 schrieb Stephan Holl:
> > Dear QGIS-users,
> > I have some questions for the WFS_plugin in QGIS.
> > Where does QGIS store the retrieved GML-file, is it stored on disk
> > or only in memory?
> > We have a quite large WFS with parcels and QGIS tries to load _all_
> > parcels at the beginning.
> > Best regards
> > Stephan
Stephan Holl <stephan.holl at intevation.de> | Tel.: +49 (0)541-33 508 3663
Intevation GmbH, Neuer Graben 17, 49074 OS | AG Osnabrück - HR B 18998
Geschäftsführer: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100224/0688943a/attachment.sig>
