[Qgis-user] Coordinate transform
Micha Silver
micha at arava.co.il
Thu Feb 25 12:00:57 PST 2010
David J. Bakeman wrote:
> I have some shape files that are in seconds rather than decimal
I'm not sure what you mean here. A shapefile is not "in seconds" or
"decimal degrees". The geometry part (*.shp) is a binary representation
of X-Y coordinates, as simple numbers. If the shapefile also has a *.prj
file, then that should contain its projection information.
If you have attribute columns (in the *.dbf part of the shapefile) with
X-Y coordinates, then you can format these columns any way you like
using, for example, Openoffice Calc. But this will *have no effect* on
the geographic location of the features in the shapefile.
So, the important question is: do the shapefiles overlay correctly? If
not, then you need to reproject one shapefile to the projection of the
others.
Hope that's clear...
Micha
> degrees. Can I create a proj4 setup that'll match them with my
> WGS84(+proj=longlat +ellps=WGS84 +no_defs) shape files? The only
> thing that's different from the WGS84 is the seconds instead of
> decimal degrees. I tried to add a unit specification but that didn't
> work.
> Thanks.
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
Arava Development Co. +972-52-3665918
http://www.surfaces.co.il
