[Qgis-user] CAD funtions plugin
Piotr Pachół piotr.pachol at wodgik.katowice.pl
Tue Jan 5 07:09:53 PST 2010
Hello Stefan,
I am very happy that you add some  CAD  functions do Qgis.
They are really useful, but still I feel lack of another CAD funtions in
Qgis.
What I really need is:
1. Adding new objects entering coordinates (in point, line or polygon
layer) just from keybord.
2. Polar measuremets: we have station point, reference point and we
enter distance and angle to get coordinates of calculated point.
3. Rectangular measurements (sometimes still useful): we have station
point, reference point and we enter 2 distances (abscissa, ordinate) to
4. Intersection from 2 points when you know two angles to set point (in
your plugin there is arc intersection when you know 2 distances to set
point).
5. Reverse intersection from 3 points (based on distances or angles).
First 3 points a really important.
What do you think about it ?
As to functionality of your plugin now each new created intersection
(orthogonal) point or line is on new layer. It is bothering when I want
to further use a group of new created objects.
So I would suggest:
1. Add some setting options, where user may point out (enter name of)
only 2 layers (point layer and line layer) where objects are written
(with intersection or orthogonal  line and point).
2. Or second solution: to make editable in the same time 2 layers  (with
points and lines) and to add new objects (intersection or orthogonal
lines and points) at these editable layers.
Regards,
Piotr
Ziegler Stefan pisze:
> Hi
> I started working on a plugin that provides some CAD functions:
> 1. Intersections of linesegments (that do not intersect)
> 2. Arc Intersection
> 3. Orthogonal digitizing
> I added another function to the plugin:
> 4. Orthogonal Line: draw an orthogonal line from a point to a line
> segment.
> Repository: http://www.catais.org/qgis/plugins.xml
> Information: http://www.catais.org/qgis/cadtools
> regards
> Stefan
> Mit freundlichem Gruss
> Stefan Ziegler
> Leiter Aufsicht
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> Rötistrasse 4
> 4501 Solothurn
> Telefon 032 627 75 96
> Telefax 032 627 75 98
> stefan.ziegler at bd.so.ch
> http://www.so.ch
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100105/9431adf2/attachment.html>
