[Qgis-user] labelling point layer
Piotr Pachół
piotr.pachol at wodgik.katowice.pl
Wed Jan 6 07:05:04 PST 2010
Hello Martin,
Is it possible to add one function in your labeling plugin ?:
It means the possibility of choosing one of layer attributes as a field
where an angle for labels is kept.
It would be very usefull for point layers and perhaps for polygon layers.
For instance I must visualize map with address numbers. Each number
should be rotated differently.
Now there is only possibility to rotate all labels with the same angle.
Regards,
Piotr
