[Qgis-user] QGIS 1.4 not linking to GDAL?
Ken Norris
ken.norris at wideband.net.au
Mon Jan 11 20:33:58 PST 2010
I think you were right Alex.
I found two GDAL installs, only one of which had MrSID and ECW
capability. Only one was removable via Synaptic - the wrong one. I since
tried to destroy everything GDAL on my machine to start again. I'll see
what happens.
But I've learnt a bit about Ubuntu in the process.
-----Original Message-----
+4288863-1004512033 at n2.nabble.com>
To: Ken Norris <ken.norris at wideband.net.au>
Subject: Re: [Qgis-user] QGIS 1.4 not linking to GDAL?
Date: Mon, 11 Jan 2010 15:33:11 -0800 (PST)
Ken Norris wrote:
> This wiki entry should give you the information you need:
> http://trac.osgeo.org/ubuntugis/wiki/UserTutorials
> Also one additional note about ecw:
http://n2.nabble.com/Ubuntu-How-to-add-MrSID-and-ECW-support-into-GDAL-td4088393.html
> Micha
> I appreciate the feedback. I certainly went through and acted on
those
> entries to install the MrSID and ECW support earlier, i.e. before this
last
> series of attempts to get QGIS 1.4 operational. Isn't the functional
> gdal_translate operation for ECW and MrSID proof of that? Certainly
the
> gdalinfo --formats comes up with:
> Supported Formats:
> Does it matter into which directories these gdal and QGIS
> files/programs/libraries are loaded? There is a chance, in the
confusion,
> that I scattered them throughout the system.
> Ken
I would look to make sure that you do not have more than one install of
GDAL. Are you using GDAL from Ubuntugis, source or another repo?
QGIS might be using a different GDAL install than the 1st one on your
path as shown by GDALformats.
Alex
Qgis-user mailing list
[hidden email]
http://lists.osgeo.org/mailman/listinfo/qgis-user
________________________________________________________________________
View message @
http://n2.nabble.com/QGIS-1-4-not-linking-to-GDAL-tp4284569p4288863.html
To unsubscribe from Re: QGIS 1.4 not linking to GDAL?, click here.
View this message in context: http://n2.nabble.com/QGIS-1-4-not-linking-to-GDAL-tp4284569p4289798.html
Sent from the qgis-user mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100111/004e7883/attachment.html>
