[Qgis-user] kmz in qgis
Agustin Lobo
alobolistas at gmail.com
Wed Jan 13 02:15:57 PST 2010
I've found the following solution that works with my fiel, not sure
if it would work in general:
1. Uncompress as if the *.kmz file were a compressed file (may be you
have to rename it to *.zip in windows). You'll get a *.kml file
2. Open the *.kml file with Qgis
Hope this work for other people as well.
Agus
maning sambale wrote:
> No it's not.
> kmz as well as kmls containing a mixture of placemarks, lines and
> polygons. In order to load kmls in QGIS or use ogr, you should create
> separate files for each vector type.
> hope that helps.
> On Wed, Jan 13, 2010 at 5:25 PM, Agustin Lobo <alobolistas at gmail.com> wrote:
>> Is not possible to open a kmz file in qgis?
>> or am I not seeing an obvious option?
>> I've tried with OGR converter also.
>> Thanks
>> Agus
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
