[Qgis-user] How to create a slope analysis?
Giovanni Manghi giovanni.manghi at gmail.com
Sun Jan 24 02:44:44 PST 2010
> The solution I've found is to use the contour sub-menu under the
> raster menu (in QGIS 1.4, OSGEO4W).
> It seems to be very similar to the contour plugin.
Actually they are very different tools.
The "contour" tool in the "raster" menu is to generate a vector contour
file from the input raster elevation model (DEM). The "contour" plugin
is for
creating contours lines from a regular points grid.
http://www.gdal.org/gdal_contour.html
http://youarealegend.blogspot.com/search/label/qgis
cheers
-- Giovanni --
