[Qgis-user] Contour Plugin installation on QGIS 1.4
Micha Silver
micha at arava.co.il
Thu Jan 28 00:24:04 PST 2010
On 01/28/2010 09:24 AM, badaveil wrote:
> Hi
> I am sharing my experience on the installation of the above on an
> Ubuntu and Windows platform:
> Ubuntu 9.10
> 1. Contour plugin won't install, requires matplotlib
> 2. Lionel Roubeyrie (Thank you) recommends terminal command "sudo
> apt-get install python-matplotlib"
> 3. Matplotib installed but contour plugin won't install, requires shapely
> 4. Copied earlier command but placed "matplotlib" with "shapely"
> (Guess work)
> 4. Shapely installed, activated QGIS
> 5. Select Plugins/fetch plugins/select contour plugin/OK
> 6. Contour plug installed at last!
> Windows XP
> 2. Matplotlib won't install, requires python >2.2
> 3. Installed python 2.6.4, Matplotlib 0.99 installed
> 4. Contour plugin won't install, requires shapely
> 5. Shapely 1.0.14 installed, Contour plugin still won't install
> 6. Give up.(I'm no programmer)
What's happening here, probably, is that the Python Shapely lib is
getting installed into the Windows version of Python, and not under the
OSGeo4W directory. QGIS uses the python that's part of OSGeo. The
easiest solution will be to add Shapely to the OSGeo4W installation (the
same way as matplotlib is). This solution has already been entered as a
request:
http://n2.nabble.com/Hello-tp4294072p4425761.html
in the QGIS trac system, so we can hope it will be solved soon.
Then you will be able to run the OSGeo4W installer, in advanced mode,
and request to install the Python matplotlib and Shapley libraries, and
then the contour plugin should work OK.
> Abbas Abdul Wahab
> http://badaveil.multiply.com
> This mail was received via Mail-SeCure System.
> Qgis-user mailing list
Micha Silver
http://www.surfaces.co.il/
Arava Development Co. +972-52-3665918
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100128/c514af57/attachment.html>
