[Qgis-user] Raster - Warp
Duarte Carreira
DCarreira at edia.pt
Wed Jul 21 07:12:27 PDT 2010
Orlando,
Boa tarde!
QGIS created a GeoTiff file. These files have coordinates inserted in the file and don't need a separate file like a tfw.
If you want to create an external tfw you can use the command "listgeo -tfw nome_da_imagem.tif".
You can get more info in Portuguese here:
http://blog.viasig.com/2009/02/gdal-como-criar-ficheiros-tfw/
Duarte
De: legio nostra [mailto:legio.patria at gmail.com]
Enviada: quarta-feira, 21 de Julho de 2010 15:11
Para: qgis-user at lists.osgeo.org
Assunto: [Qgis-user] Raster - Warp
Hello everyone,
I used the tool gdal: Raster - Warp - to send a raster image (. TIF) with the coordinates EPSG: 27492 EPSG for coordinates: 20 790.
What did perfectly, but the question I ask is this: There is no set file types:. Tfw; wld, etc..? Is there any other function that does that?
This image, which project had the coordinates EPSG: 27 492, with the same name had a file with the extension. Tfw,
When the reprojected image. Tif for the EPSG coordinate: 20 790 there has been no change in that file.
I know that if the image was georeferenced, a file was created with the new coordinates and with the extensions. Wld
Thanks for the help
Orlando Bernardo
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20100721/8464f5fb/attachment.html>
