[Qgis-user] Re: compiled qgis1.5 but have no Python support
Ricardo Filipe Soares Garcia da
ricardo.garcia.silva at gmail.com
Sun Jul 25 09:12:14 PDT 2010
Hello
Problem solved, I was just missing some dependencies. I re-read the
INSTALL document that comes with the source and everything was
cleared. Sorry for the noise
On Sun, Jul 25, 2010 at 10:40 AM, Ricardo Filipe Soares Garcia da
<ricardo.garcia.silva at gmail.com> wrote:
> Hello all
> I am using Kubuntu 10.04. I was using Qgis 1.4 from the ubuntugis ppa,
> which worked fine.
> After compiling the new Qgis 1.5, python support is no longer enabled.
> I am getting the following error when I start Qgis:
> Couldn't load PyQGIS.
> Python support will be disabled.
> Traceback (most recent call last):
> File "", line 1, in
> ImportError: dynamic module does not define init function (initcore)
> Python version:
> 2.6.5 (r265:79063, Apr 16 2010, 13:28:26)
> [GCC 4.4.3]
> QGIS version:
> 1.5.0-Tethys 'Tethys', 13958
> Python path:
> ['/home/ricardo/programas/qgisTrunk/share/qgis/python',
> '/home/ricardo/.qgis/python', '/home/ricardo/.qgis/python/plugins',
> '/home/ricardo/programas/qgisTrunk/share/qgis/python/plugins',
> '/usr/local/lib/python2.6/dist-packages/dbf-0.87.14-py2.6.egg',
> '/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
> '/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
> '/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
> '/usr/lib/python2.6/dist-packages/PIL',
> '/usr/lib/pymodules/python2.6',
> '/usr/lib/pymodules/python2.6/gtk-2.0',
> '/usr/lib/python2.6/dist-packages/wx-2.8-gtk2-unicode',
> '/usr/local/lib/python2.6/dist-packages']
> I noticed that, during compilation, there were some change issues that
> had never happened to me before. The 'make' process would exit with an
> error, complaining about not finding some sip or qt4 related stuff,
> but after I retried it went on just fine. This happended three times.
> I don't know if it is related, because the compilation ended
> successfully, but I will recompile and post the exact errors, if they
> are relevant.
> Thanks for your help
> ___________________________ ___ __
> Ricardo Garcia Silva
