Hello list,
I'm having trouble opening an spatialite database that I created by importing
a shapefile. When I try to open the db, I get a message saying:
"Failure while connecting to:
/path/to/filename.sqlite
seems to be a valid SQLite DB, but not a SpatiaLite's one..."
I've found a couple references to this error in my searches online, but
nothing conclusive yet.
I created the file by opening the db with 'spatialite /path/to/filename.db',
then used the .loadshp command to import a shapefile into the database. The
data appear to be fine, and I can query it and the geometries all seem to work
(e.g., "select area(Geometry) from tablename;" produces the expected output).
I also have the same problem if I use the OGR conversion utility in QGIS to
convert a shapefile to SQLite - though I'm guessing in this case it's because
OGR isn't creating an actual SpatiaLite file.
I'm doing this using QGIS 1.5 on 64-bit Ubuntu. Here's the version
information from spatialite:
SpatiaLite version ..: 2.4.0 Supported Extensions:
- 'VirtualShape' [direct Shapefile access]
- 'VirtualDbf' [direct DBF access]
- 'VirtualText' [direct CSV/TXT access]
- 'VirtualNetwork' [Dijkstra shortest path]
- 'RTree' [Spatial Index - R*Tree]
- 'MbrCache' [Spatial Index - MBR cache]
- 'VirtualFDO' [FDO-OGR interoperability]
- 'SpatiaLite' [Spatial SQL - OGC]
PROJ.4 version ......: Rel. 4.7.1, 23 September 2009
GEOS version ........: 3.2.2-CAPI-1.6.2
SQLite version ......: 3.6.22
Is there something incompatible here, or am I doing something wrong in the
creation of the SpatiaLite DB?
Regards,
Mike
