[Qgis-user] postgis layer from a view
Lionel Roubeyrie
lionel.roubeyrie at gmail.com
Tue Jun 1 03:16:28 PDT 2010
Hi Bernhard,
thanks to responding. I have modified the view to retrieve the "gid"
column form a table, which is a primary key with unique values, and
not from a sequence, but postgis provider complains again about no
unique values oO
Here is the table :
CREATE TABLE spatial.commune
code_insee character varying(5),
region character varying(20),
the_geom geometry,
gid serial NOT NULL,
CONSTRAINT commune_pkey PRIMARY KEY (gid),
CONSTRAINT commune_gid_key UNIQUE (gid),
CONSTRAINT enforce_dims_the_geom CHECK (st_ndims(the_geom) = 2),
CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
'MULTIPOLYGON'::text OR the_geom IS NULL),
CONSTRAINT enforce_srid_the_geom CHECK (st_srid(the_geom) = 2154)
and the problematic view :
CREATE OR REPLACE VIEW residentiel.spatial_nrj_sourcesfixes AS
SELECT com.gid, nrj.id, nrj.cmbl, nrj.commune, nrj.region, nrj.cha,
nrj.ecs, nrj.cui, nrj.spe, nrj.total, com.the_geom
FROM residentiel.nrj_sourcesfixes nrj
JOIN spatial.commune com ON nrj.commune::text = com.code_insee::text;
the residentiel.nrj_sourcesfixes is another view.
2010/6/1 Bernhard Ströbl <Bernhard.Stroebl at jena.de>:
> Dear Lionel,
> AFAIK the view must contain a field being defined as primary key in the
> underlying table, moreover this field must be of type integer.
> The view must be defined in a way that every element (thus every primary-key
> value) is unique. In case the view contains a join resulting in several
> primary-key fields you can choose which one QGIS should use.
> So your view definition lacks the primary-key field, although the sequence -
> of course - populates gid with unique values.
> Maybe you could post the complete view definition (and the table
> definitions, too) and we could see if we could help you in creating a
> working view.
> regards
> Benno
> Lionel Roubeyrie schrieb:
>> Hi all,
>> I can't load datas from a postgis view, the loader complains about no
>> uniques values and int4 type, however the view starts with "SELECT
>> nextval('my_seq'::regclass)::integer AS gid, com.the_geom, ..." (the
>> gid column is not listed in the error message) which works perfectly
>> if datas are stored in a table. Is there a trick to load datas from
>> views, and more generally is it possible to force the postgis provider
>> to create an internal unique key?
>> Thanks
> ________ Information from NOD32 ________
> This message was checked by NOD32 Antivirus System for Linux Mail Server.
> http://www.nod32.com
Lionel Roubeyrie
http://youarealegend.blogspot.com
