[Qgis-user] Re: [Qgis-developer] GdalTools in trunk
Tim Sutton
lists at linfiniti.com
Fri Jun 4 03:21:36 PDT 2010
Hi
I guess having 'dev' in the release name is causing issues.... (see below).
Regards
Tim
Couldn't load plugin GdalTools due an error when calling its initGui() method
File "/home/timlinux/apps/share/qgis/python/qgis/utils.py", line
159, in startPlugin
plugins[packageName].initGui()
File "/home/timlinux/apps/share/qgis/python/plugins/GdalTools/GdalTools.py",
line 86, in initGui
self.GdalVersion = Utils.Version( Utils.GdalConfig.version() )
File "/home/timlinux/apps/share/qgis/python/plugins/GdalTools/tools/GdalTools_utils.py",
line 347, in version
return Version(gdal.VersionInfo("RELEASE_NAME"))
line 613, in __init__
self.vers = self.string2vers(ver)
line 623, in string2vers
vers[1] = int(nums[1])
ValueError: invalid literal for int() with base 10: '8dev'
Python version:
2.6.5 (r265:79063, Apr 16 2010, 14:15:55)
[GCC 4.4.3]
QGIS version:
1.5.0-Trunk Trunk, 13642
Python path: ['/home/timlinux/apps/share/qgis/python',
'/home/timlinux/.qgis/python', '/home/timlinux/.qgis/python/plugins',
'/home/timlinux/apps/share/qgis/python/plugins',
'/usr/local/lib/python2.6/dist-packages/django_tinymce-1.5-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/gearman-1.5.0-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/django_simple_captcha-0.1.7-py2.6.egg',
'/usr/local/lib/python2.6/dist-packages/django_extensions-0.5-py2.6.egg',
'/usr/lib/python2.6', '/usr/lib/python2.6/plat-linux2',
'/usr/lib/python2.6/lib-tk', '/usr/lib/python2.6/lib-old',
'/usr/lib/python2.6/lib-dynload', '/usr/lib/python2.6/dist-packages',
'/usr/lib/python2.6/dist-packages/PIL',
'/usr/lib/python2.6/dist-packages/gst-0.10',
'/usr/lib/pymodules/python2.6',
'/usr/lib/python2.6/dist-packages/gtk-2.0',
'/usr/lib/pymodules/python2.6/gtk-2.0',
'/usr/local/lib/python2.6/dist-packages',
u'/home/timlinux/.qgis//python/plugins',
'/home/timlinux/apps/share/qgis/python/plugins/fTools/tools',
'/home/timlinux/apps/share/qgis/python/plugins/GdalTools/tools',
'/home/timlinux/apps/share/qgis/python/plugins/GdalTools', '.']
On Fri, Jun 4, 2010 at 4:33 AM, Giuseppe Sucameli <brush.tyler at gmail.com> wrote:
> Hi guys,
> now GdalTools plugin v.1.2.0 is in trunk.
> So, if you have to open a ticket you must use the qgis trac.
> For the translators: remember that you must update the translations
> on the qgis repository and not in the Faunalia one.
> Cheers.
> Giuseppe Sucameli
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
