[Qgis-user] Points2one - group by input field
MORREALE Jean Roc
jr.morreale at enoreth.net
Sun Jun 6 04:58:01 PDT 2010
Le 05/06/2010 21:00, Goyo a écrit :
> El vie, 04-06-2010 a las 14:47 +0200, MORREALE Jean Roc escribió:
>> It would be great if the plugin could parse the file, group the
>> feature points sequentially by the input field and only then draw
>> the polygon as it would allows a surveyer to stop collecting a long
>> feature to collect a small nearby feature and then resume on the
>> previous one.
> Please install version 0.2.2 of the plugin and see if it does what
> you need. It allows you to sort the points by the grouping attribute.
> You'll find it in the plugin installer.
Hi goyo,
Unfortunately I can't test the version "0.2.2 (0.2.0)", when installing
I get this error :
"The plugin seems to have been installed but I don't know where.
Probably the plugin package contained a wrong named directory.
Please search the list of installed plugins. I'm nearly sure you'll find
the plugin there, but I just can't determine which of them it is. It
also means that I won't be able to determine if this plugin is installed
and inform you about available updates. However the plugin may work.
Please contact the plugin author and submit this issue."
And this on clean qgis install without the previous version of
points2one (0.2.0), which is still showing up in the list), the folder
is created and filled in ~/.qgis/python/plugins.
Regards,
Jean Roc
