[Qgis-user] Problem opening kml files
=?ISO-8859-1?Q?Ant=F3nio_M?=. Rodrigues
amrodrigues at fcsh.unl.pt
Sun Jun 6 11:25:03 PDT 2010
I just found that "Since GDAL 1.6.1, folders containing multiple geometry types, like POINT and
POLYGON, are supported". I have in my system GDAL frameworks 1.6 and 1.7. Could it be that QGIS
is using the older version?
How can I check/correct this?
Thank you
On Sun, 6 Jun 2010 19:12:16 +0100, António M. Rodrigues wrote
> Hi all,
> I want to open a kml file in QGIS1.4 (MAC OS). If the file is made
> of points (with any number of layers), it opens fine. If there's a
> lines layers, it just says: filename.kml "is not a valid or
> recognized data source". I tried diffferent files, all saved from
> Google Earth, and none works.
> Any help?
> Thanks,
> António
> Qgis-user mailing list
